Question about ATG limitations
Postby dead1 » 11 May 2017
Not a criticism before anyone takes this as one.
1. Currently you can generally only buy 1 light/medium AT gun per infantry platoon (some exceptions like Soviets in BGK). Note these type of weapons were often assigned to infantry formations and also formed the large majority of AT assets at divisional level.
2. Heavy AT guns are often restricted but can be brought in larger numbers as specialist support than light/medium ATGs. These were often assigned in separate battalions within a division and were often not assigned to independent formations that were doled out to divisions/army groups as needed.
3. Self Propelled AT guns like Marders or M10s can also be brought in larger numbers (often as individual platoons under tank options). Most SP AT assets were available in smaller numbers than ATGs in most divisional level organisations A lot were assigned to independent formations that were then assigned to divisions/army groups as needed (especially in Soviet and German armies).
How come there's a limit on light/medium AT assets? Should they be available as a specialist support asset as well as infantry platoon support?
(Personally I just house play you can take more ATGs as a Specialist Support option if you pay the points for them without need to buy an infantry platoon).
dead1
Mayday
2014 build (1)
Re: Question about ATG limitations
Postby Powermonger » 11 May 2017
Actually there are several cases where you can buy light / medium AT batteries as a specialist support option:
Panzerjaeger battery in BGBlitz: 2x pak36
Panzerjaeger battery in BGBarb: 2x Pak 36
PanzerJaeger Battery in BGBarb: 2 x pak 38 (panzer div only)
Panzerjaeger battery in BGWaR: 2x Pak 40 (Volksgrenadier list)
Russian AT gun battery in BGBarb: 3 (three!!) x 45mm AT guns
Regards,
Diego
You may be Powermonger, but I´m Powerowner
Powermonger
Recce campaigner (1)
You can also buy a 45mm ATG battery in Kursk as well.
Anything Russian can still buy large number of ATGs even without access to a dedicated battery. I'm talking about on table ZIS-3 artillery batteries. Russians used ZIS-3 in a lot of AT units and even the artillery ones were used direct fire from what I've read.
Still your average Allied or German platoon can more easily load up on SPGs and heavy ATGs than lighter "regimental" ones.
dead1
Mayday
2014 build (1)
Postby Piers » 11 May 2017
If you want more in a historical scenario then go for it... we do. :grin:
 ‘Landed. Killed Germans. F***ed off.’ - Major Anders Lassen's operational report to the Admiralty.
'...its not a realistic expectation, that you can use a tank as a sort of big 'fruit-squashing' machine' - Woz
Piers
Dominic Greene
Medals: 41
Capt Campaigner (1) Cav Campaigner (1) Arty 1st place (1) Comm 2nd place (1) Sur1 campaigner (1) Afloat Campaigner (1)
England Campaigner (1) Flak Campaigner (1) Comms Campaigner (1) Armour 3rd place (1) Terrain2 1st place (1) fortified 1st place (1)
Recce 2nd place (1) Leader Campaigner (1) Casualty 1st place (1) Female Campaigner (1) Sniper Campaigner (1) 40mm 2nd place (1)
Wings Campaigner (1) POW Campaigner (1) Truck Campaigner (1) 30mm 1st place (1) Red Campaigner (1) Green 1st place (1)
AntiTank Campaigner (1) Easter14 2nd place (1) 60mm 2nd place (1) Lib Minis 1st (1) Terrain Campaigner (1) Brit Minis 2nd place (1)
Scen1 Campaigner (1) Big Game 2010 (1) 2010 Build (1) 2011 Build (1) 2012 Build (1) 2013 Build 3rd place (1)
xmas15 2nd place (1) xmas14 campaigner (1) 2014 build 3rd place (1) 2015 build 2nd place (1) 2016 build 2nd place (1)
Postby Ray » 11 May 2017
Piers wrote:If you want more in a historical scenario then go for it... we do. :grin:
Same here :thumbsup:
SOTCW 118
Ray Haskins
Fulltime figure painter.
No Job too small or big.
10% Discount to fellow Guilders.
Ray
Armour Campaigner (1) Terrain2 Campaigner (1) Recce campaigner (1) Ambulance campaigner (1) quick campaigner (1) 2015 build campaigner (1)
Postby Mahti » 12 May 2017
It would be good idea to give option to field more light at guns from specialist support in future books. It certainly wouldn't be a problem from historical or balance point of view.
Mahti
Baron Samedi
Users browsing this forum: skip and 6 guests
