New force builder for Battlegroup Kursk
Re: New force builder for Battlegroup Kursk
Postby Robak » 03 May 2014
Despite of a great job you did I've found a little mistake. KV-1 platoon has 6BR instead of 9BR in Russian rifle divison.
Robak
Helga Brandt
Postby Historical Wargamer » 15 May 2014
In a recent Soviet Rifle Division based force I selected a battery of 45mm AT guns from Specialist Support Units. If you select a truck for towing--it adds 4 points only to the total BR, instead of 12 for three trucks (+4 per gun). Not a big deal--but when you have time.
Thanks again for the great software.
Historical Wargamer
Baron Samedi
Postby Richard » 18 May 2014
Going through the force builder for US infantry, what is the infantry gun option
I think it could be a half track mounted 75mm, but would like confirmation
Some like the fishing, some like the violin, some like the sound of cannonballs a'rolling
[url]http://corporal-schmitt.blogspot.com[/url]
Richard
Sandor
Medals: 5
Armour Campaigner (1) Terrain2 Campaigner (1) AntiTank Campaigner (1) Easter14 Campaigner (1) Ambulance campaigner (1)
Postby andyt » 06 Jun 2014
Seem to have found a couple of minor anomalies in the Russian Rifle Division list for Kursk, which need correcting when time allows.
The Heavy Artillery Battery is showing as 0 BR and should be 4 BR.
The KV1 Platoon is showing as 6 BR and should be 9 BR.
Andy
andyt
Tee Hee
Postby Jedirev » 01 Jul 2014
Hi,
Don't know why I've never noticed this - but the print out doesn't produce a stat block for the Loyd Carrier in the British Infantry Platoon.
/Jedi
Jedirev
Rosa Klebb
Postby Historical Wargamer » 05 Jul 2014
I've found another glitch.
The cost of an 88/71 AT gun lists at 71 points in the BG Overloard German Infantry Division list. But if you try to add an SdkF 7 to tow it, which is only 8 points, the cost of the weapon goes up to 102 points instead of 79 points. The same error does not occur under the Overlord German Armored Division units for the same weapon.
I appreciate the effort that has gone into the site and am only trying to help improve it! I wish that I could help update it. Thanks again for providing the resource.
Historical Wargamer
Baron Samedi
Postby bloodydrake » 10 Jul 2014
I found a data error in the FOTR soviet rifle battlegroup.
When you select a su-battery selection of 2 su-85s in the tank section the print form shows 2 su-76's and the su-76 gun types.
love the program great work btw
bloodydrake
Gruntha
Postby Historical Wargamer » 10 Jul 2014
Agreed it is a great program.
Found minor issue with the American Armored Division, Artillery Section. The Heavy Mortar Team lists at the correct points (29), but shows 0 Battle Rating. The book shows 1 BR for the Heavy Mortar Team.
Also, if you select three (3) M10s from the Tank Section, the print out only shows one M10 stat line instead of three.
Minor issues, but I wanted to submit for hopefully eventual correction. I again add that I appreciate all the effort that has gone into the BattleGroupBuilder site and what a beneficial aid it is for the BG rules.
Historical Wargamer
Baron Samedi
Postby Peabody » 03 Aug 2014
Just built a Company Level list for an upcoming Holiday Weekend BGK game... Actually I built several and now I'm spoiled for choice!
:thumbsup: :cool:
Simply an amazing tool.
Peabody's Wargaming Miniatures Blog.
Television is rather a frightening business. But I get all the relaxation I want from my collection of model soldiers. P. Cushing
Peabody
Flak Campaigner (1) Building 2nd place (1) Armour Campaigner (1) Terrain2 Campaigner (1) 2012 Build (1) 2014 build (1)
Postby quozl » 07 Aug 2014
Robak wrote:Despite of a great job you did I've found a little mistake. KV-1 platoon has 6BR instead of 9BR in Russian rifle divison.
Historical Wargamer wrote:battery of 45mm AT guns from Specialist Support Units. If you select a truck for towing--it adds 4 points only to the total BR, instead of 12 for three trucks (+4 per gun).
Both fixed. Thanks for that guys.
quozl
Mr Kidd
andyt wrote:S
and
Jedirev wrote:Hi,
both fixed now. Thanks lads.
quozl
Mr Kidd
Historical Wargamer wrote:The cost of an 88/71 AT gun lists at 71 points in the BG Overloard German Infantry Division list. But if you try to add an SdkF 7 to tow it, which is only 8 points, the cost of the weapon goes up to 102 points instead of 79 points.
Fixed.
and
bloodydrake wrote:When you select a su-battery selection of 2 su-85s in the tank section the print form shows 2 su-76's and the su-76 gun types.
fixed
quozl
Mr Kidd
Historical Wargamer wrote: The Heavy Mortar Team lists at the correct points (29), but shows 0 Battle Rating.
Both fixed. Thanks for letting me know :)
quozl
Mr Kidd
Postby Historical Wargamer » 08 Aug 2014
Thanks to you for making the corrections and all the hard work that you put into the site. I know many of us appreciate all your efforts. BGBuilder really enhances the BG rules and our gaming efforts. If we ever meet the first three rounds are on me (and after that the rest will probably be also)!
Historical Wargamer
Baron Samedi
Postby quozl » 08 Aug 2014
Thanks Historical Wargamer. Since having twin boys about 3 years ago my drinking tolerance is so low that after 3 pints you could probably convince me to give you my wallet. So you might even make money out of it!
The Barbarossa Panzer Division list is up now everybody. Any bug reports welcomed.
quozl
Mr Kidd
Postby Dominatus » 09 Aug 2014
Sweet, thanks Quozl you really rock :good: Twins are crazy! I have younger twin brothers.
Dominatus
Professor Dent
Postby bloodydrake » 24 Aug 2014
Awesome news Quozl! Thankyou you very much for all your hard work
bloodydrake
Gruntha
Postby Historical Wargamer » 23 Sep 2014
The same issue noted above in the U.S. Overlord Armored Division (now corrected thank you) is showing up in the U.S. Overlord Infantry Division list.
In infantry list Artillery Section the Heavy Mortar Team lists at the correct points (29), but shows 0 Battle Rating. The book shows 1 BR for the Heavy Mortar Team.
Thanks again!
Historical Wargamer
Baron Samedi
Postby Historical Wargamer » 03 Oct 2014
Just noticed that in an American Armored Fall of the Reich list that if you select a platoon of three M10s, M18s, or M36s that only one shows up in the print list. Also, the weapon for the M26 Pershing tank does not show up in the print list.
Thanks
Historical Wargamer
Baron Samedi
Postby Historical Wargamer » 06 Oct 2014
Found couple more minor things.
In American Infantry force list:
If you select "Infantry Gun" (27 point, 2 BR unit) in an Infantry Platoon options, the weapons stats/ammo lines do not show up in the print out.
In Tank Units, if you select 5 - 76L53 guns, but forgot to change the Composition entry to 5 M4s (from 3 M4s default), the 5 M4-76L53s will show up in the print out 100 points short (i.e. as long as you select 5 M4 Shermans in the Composition and then select 5 76L53s in the box below that it works fine--but thought I'd mention it in case).
Thanks again!
Historical Wargamer
Baron Samedi
PreviousNext
Users browsing this forum: No registered users and 3 guests
